Chysn's Gear Rant Thread...
  • 1304
Re: Chysn's Gear Rant Thread...
« Reply #180 on: October 02, 2020, 01:38:26 PM »
I am mostly divesting from eurorack in conjunction with getting a Pro-3. I prefer to avoid having multiple synthesizers in favor of a clean space.
I can't get out of euro entirely, because I developed a fairly popular eurorack product, and I can't just leave it behind, and don't really want to.
Also, there are things that the Pro-3 doesn't do, and eurorack modules can fill in these gaps. So I'm basically going to start my eurorack system from near-scratch after I get the Pro-3.
My four years of nearly-exclusive eurorack use have been valuable, though. I learned a lot more about synthesis in general, and there are techniques that I can adapt that I wouldn't have considered before, that are supported by the Pro-3.
Pro 3
Previous: Mopho Keyboard, Desktop Mopho, Evolver, DSM01, DSM03
Software: macOS, Ableton, MuseScore2, Serum, Pianoteq
« Reply #181 on: October 02, 2020, 01:52:48 PM »
In my view the best aspect of a Eurorack or even semi-modular experience is that it forces one to kind of think from the ground up and to recognize that all the single building blocks can have multiple purposes like VCAs for example. That can spur some creativity and also help in understanding how certain outcomes can be achieved most efficiently. It's a bit like going back to school. And I'm sure you will continue to benefit from that. In addition, using the Pro 3 might be very motivational as well, as Sequential improved so many things with regard to the workflow since the instruments you last used by them (I believe the Mopho, Tetra, and Evolver).
  • 1304
« Reply #182 on: October 02, 2020, 02:20:52 PM »
Yes, thatís surely a part of it. Another part of it is the diversity in the kinds of building blocks you have. Things that are generally missing in most hard-wired synths include logic, switches, rectifiers, inverters, shift registers, comparators, lag processors, and many others... things that allow a synth to make decisions based on human control, or indirectly based on something that happened elsewhere.
But, the Pro-3 has these CV jacks, so I shanít miss those things. Even just a Pro-3 and Hemisphere Suite will cover almost all those bases.
Pro 3
  • 1304
« Reply #183 on: October 03, 2020, 08:50:07 PM »
I spent some time today getting started on a Pro-3 wavetable library in C. My wav2evolver PCM library gave me a really good start and, using that, I'll be able to do some things that Sequential's web-based wavetable generator can't yet do (automatic bit depth conversion, sample size conversion using linear interpolation, handling of stereo waves, use of raw PCM data).
I have a pretty good understanding of the wavetable sysex format at this point, as it's mostly straightforward; but since I don't have a Pro-3 yet, I have some gaps in knowledge. For example, there are 16 "reference" waves, but the format puts two extra waveforms between each of these, for a total of 48 waveforms.
My first idea was that maybe the Pro-3 doesn't calculate morphing between waveforms in real time, and that that is done by the generator. But this doesn't seem to be borne out by the content of the interstitial waves. My second idea was that maybe they're for future expansion for another Sequential synth, probably not the Pro-3. My third idea is that they're for transposition, as they appear to contain interpolated variations of the reference waveform at different frequencies. I think the third idea is the most likely.
I'd welcome insight on this if anybody has some. Otherwise, I'll figure it out through experimentation later this month.
One of the things you'll be able to do from a wav2evolver update is generate a Pro-3 wavetable from an Evolver custom waveform. That is, you'll get a Pro-3 wavetable containing a single Evolver waveform  :) . This absurd feature will be dedicated to Razmo, because I think he'd have gotten a kick out of it.
« Last Edit: October 03, 2020, 09:00:37 PM by chysn »
Pro 3
  • 1304
« Reply #184 on: October 04, 2020, 06:30:49 AM »
I shouldn't look at them as 48 waveforms. It's sixteen groups of a single waveform at 1/1, 1/2, 1/4, 1/4, and (1/8)x8. I get the format now.
Pro 3
  • 1304
« Reply #185 on: December 07, 2020, 06:05:35 PM »
Well, there it is. I've ordered a Pro 3.
I decided to go with the standard edition. I went back and forth about a million times, with the understanding that I'll be happy with either one. In the end, I framed the decision as one between the "Minimoog Aesthetic" and the "Pro-One Aesthetic," and came down on the side of tradition.
But with that little matter out of the way, I'm excited for my instrument's arrival. I've got a good start on my wavetable generation software, and I'll take another look at the manual while my Pro 3 slowly makes its way from California to Michigan.
« Last Edit: December 07, 2020, 06:07:36 PM by chysn »
Pro 3
« Reply #186 on: December 07, 2020, 06:12:05 PM »
Congratulations, Chysn.  I'm sure the Pro 3 will add some excitement and inspiration to your music-making.
  • 1304
« Reply #187 on: December 07, 2020, 08:19:18 PM »
It will be both a radical departure and a homecoming. The Pro 3 is exactly what I wanted in 2016, but then I took a four-year detour. When it was introduced a year ago, I started making long-term plans to get one. When Sequential made the user wavetable update, that pretty much sealed my fate.
Pro 3
« Reply #188 on: December 08, 2020, 01:51:44 AM »
Congratulations! Looking forward to hearing what you will come up with.
« Reply #189 on: December 08, 2020, 06:19:59 AM »
Congrats. I got my SE at the weekend (for the same price as the standard so a no-brainer). Itís lovely. Sadly Iíll need to get an exchange as one of the encoders is defective. But itís so nice to play. Found a couple of weird bugs which Iíve reported too: single program dump isnít working - the write button does nothing in that case. Also some weird stuff happening with the ladder filter on one patch I made where it sounds like the filter is being FMíd when it isnít and the other two filters are fine.
My Subsequentís future is looking less secure.
  • 1304
« Reply #190 on: December 08, 2020, 06:38:10 PM »
December 15th.
Good news is, I'm off from the 18th to the end of the year, so I'll have plenty of time to learn it.
Bad news is, it's going to be a l...o...n...g... week.
Pro 3
  • 1304
« Reply #191 on: December 15, 2020, 02:38:23 PM »
'Tis the season to connect my new Pro 3 to the Voltage-Controlled Christmas Tree! In real life, it's flashing courtesy a couple of LFOs at different rates.
Well, the Pro 3 has four CV outputs, so for next year I'll have to work on the Voltage Controlled Christmas Tree Mark 2.
« Last Edit: December 15, 2020, 02:40:15 PM by chysn »
Pro 3
  • 1304
« Reply #192 on: December 16, 2020, 02:50:45 PM »
I'm reading through the manual from the beginning, so that I don't miss anything. It's a really good manual, and I have a pretty good handle on basic editing, and the capabilities of the sound engine. I'm thrilled with the more knob-per-function design of the panel, as compared to the Mopho Keyboard, with each oscillator having its own knobs, and most envelopes having their own knobs.
I've gone into the sequencer a little bit, without having actually reached the sequencer section of the manual. So there's quite a bit of mystery there. I'm still surprised to see so many new colors pop up on those buttons.
I have successfully imported a wavetable generated by wav2evolver. I found that I needed to slow down sysex transmission to get that to work. Once I've got a good handle on the instrument itself, I'll continue working on my wavetable generator C library.
Pro 3
  • 1304
« Reply #193 on: December 18, 2020, 11:09:27 AM »
Here's a thing that the Pro 3 standard edition really should've come with, in my opinion. I got this on Ebay for a few bucks.
The positioning to the right of the wheels might seem odd, but this is where the badge was on the Pro One, probably because there was a screw in the way of flushing it left.
I've always wondered where the "Circuits" went when the Sequential name came back.
« Last Edit: December 18, 2020, 11:11:26 AM by chysn »
Pro 3
« Reply #194 on: December 18, 2020, 11:56:24 AM »
Classy.  ;)
I think the Drumtraks from 1984 was the last product that had "Sequential Circuits" printed on it.
  • 1304
« Reply #195 on: December 18, 2020, 07:08:18 PM »
"Circuits" in a trade name absolutely screams 1980s, in much the same way that "Solutions" in a trade name screams 2000s.
The Sequential Circuits domain name goes to Wine Country, which is fair, I guess.
Pro 3
« Reply #196 on: December 19, 2020, 02:10:29 AM »
Indeed.  ;D
I think Dave once mentioned that they went with "Sequential" only because the shortened name became the default during the 1980s and because he simply prefers the shorter version.
  • 1304
« Reply #197 on: December 20, 2020, 09:21:22 AM »
I'm off work for the rest of the year. My main project during this time* is working on my Pro 3 wave table software.
I'm finishing up the processing library, which is in C, and that's mostly done. It's generating system exclusive files, and just needs more testing and refinements. The longer stage will be development of a web-based interface.
The library can read and convert most types of WAV files. So if you provide WAV files of different sizes, or 32-bit WAVs, or ones in stereo, the library won't care, it'll convert them to the proper format.
But the major feature is that you can generate a wave table with any number of reference waves between 1 and 16. You can place these in any reference waveform positions you want, and then the library will fill in the gaps with linear interpolation. For example, the attached wave table was generated using three waveforms generated by Audacity, saw, square, and sine. I placed these in reference waveforms 1, 9, and 16, respectively, and the library filled in the rest:
(The top part is the individual reference wave set, and the bottom is partial unpacked sysex with the downsampled waveforms)
The attached sysex file works nicely (wave table #33), and you can hear the morphing from one waveform to the next.
Probably later this week I'll release the code to GitHub for anybody to use, and I'll start the web interface.
* You know, other than enjoying time with my family and doing peace on earth and goodwill toward humankind
« Last Edit: December 20, 2020, 09:41:20 AM by chysn »
Pro 3
