Factory Reset or Deleting numbers files
« on: April 03, 2019, 03:37:44 AM »
I just bought Tempest as second hand.
I'm trying to save new sounds but the system says memory is full. I need only factory sounds so there is a way like factory-reset or deleting sounds at once? I tried system reset but it still holds sounds and only approach I can found from manual is deleting sounds one by one..
Re: Factory Reset or Deleting numbers files
« Reply #1 on: April 03, 2019, 04:15:05 AM »
Hi and welcome to the forum,
You have 2 choices...Either the one you’ve described by deleting Projects/Beats/Sounds/ one by one or formatting Tempest and loading the factory content.
To enter system root menu hold both Shift buttons and hit system.
Also i suggest you should check out the sticky threads and especially this one:
https://forum.sequential.com/index.php/topic,78.0.html
« Reply #2 on: April 03, 2019, 06:07:38 AM »
Hi Yorgos,
Thanks for quick answer and suggestion. I'm starting read the thread you paste, and It is great!!
I might miss something but how can I format Tempest? I could only find "Reset System Parameters" in System Menu.
« Reply #3 on: April 03, 2019, 06:09:28 AM »
Press both shift buttons and at the same time hit system button
« Reply #4 on: April 03, 2019, 07:05:46 AM »
Oh I missed "both" and now I found the menu. Thanks so much!!
« Reply #5 on: April 08, 2026, 05:39:11 PM »
I updated my Tempest using the firmware and soundsets, but the beats are not there. Can someone please help me find them? Thanks!
