Hi All,
I use unison mode a lot...and I much prefer that the latest ("last") note get precedence over the default precedence, which is the lowest note ("low"). So, on all my patches, I change Key Mode to "Last". Easy.
On my Prophet 6 (1.2.0), however, playing the sequencer and then stopping the sequencer seems to change the Key Mode back to "low". It's quite annoying.
Note that for this bug does not occur in poly mode. You have to be in Unison mode when you activate the sequencer. Then, when you stop sequencer, you'll see that the Key Mod has switched to low.
Any chance for a fix? Or is it a feature?
Chip
