Adding samples in a user
laurentluigi
« on: March 18, 2019, 04:19:49 AM »
Hello everyone,
Before trying a make a mess... I would like to ask a question.
I had some troubles in the past using the sample utility software, like few of us, and the client support send me a brand hard disk.
Do you think I can had samples in a user that already had samples....??
I mean, on user 2, I've got a wavetable on 1/Ambiance...
If I want to add more, if I write on the usb stick px\u02\03 Piano (or other correct number and name corresponding in the Px), do you think it will be ok....
As you imagine... I will not try without your commentary....
(This is a (not very) subliminal message to the one and only Lady Gaia....!!!)
Thanks everyone !!
Re: Adding samples in a user
« Reply #1 on: March 18, 2019, 07:26:09 AM »
Sequential assures me that installing user samples is additive: you can safely install additional samples into the same group with no problems.  Indeed, I have done so myself many times.  New additions will only replace existing samples if they share the same group (u02 in this example), category (which they don't in your example, Piano and Ambiance are distinct categories) and sound set # within a category (the "02" part of "02. Neutron VCO|Triangle".)
laurentluigi
« Reply #2 on: March 18, 2019, 07:54:46 AM »
Thank You very much !!
Still the One !
Au revoir !!!
