After 1.1.4.27 update, my keyboard is tuned to F (did calibrate)
« on: February 24, 2019, 01:53:04 AM »
Hello,
I'm having this problem where i've just updated to 1.1.4.27, did the calibration, then it was OK.
Switched off the prophet then go back to it in the afternoon and now it's tuned to F. Meaning, when i press C it's an F.
I tried calibrating again and it stays to the weird tuning. I've tried the basic patch to no avail.
Anyone had this problem before ?
Thanks,
James
shiihs
  • 103
Re: After 1.1.4.27 update, my keyboard is tuned to F (did calibrate)
« Reply #1 on: February 24, 2019, 02:00:02 AM »
Hello,
Thanks,
James
The 1.1.4 series at some point had tuning problems (I don't recall the exact versions though). But why upgrade to 1.1.4.27 if there's 1.1.5.9 available?
links:
shiihs
  • 103
« Reply #2 on: February 24, 2019, 02:10:04 AM »
Also be sure to check if you didn't configure a transposition via global -> master coarse
links:
« Reply #3 on: February 24, 2019, 04:35:22 AM »
Thanks for your reply shiihs,
Just updated to 1.1.5, first was tuned to C.
Switched off/on. Back to F :(
« Reply #4 on: February 24, 2019, 10:48:40 AM »
After checking what shiihs suggested you should calibrate the mod wheel.
« Reply #5 on: February 25, 2019, 09:19:39 AM »
Apparently, this has resolved the issue :) thanks, i'll set this to resolved tomorrow because of the erratic behavior of my synth...
