Volume trickery:
Since osc 1&2 use a mix knob, rather than a dedicated volume knob, workarounds are needed. Using only 1 of the 2 analog oscs is a well known option, but you lose one osc. I came up with another solution, it's not useful for every sound, but it is useful
- when using a pulse wave on osc 2 (so you can use osc one for fm), @ 0% there is no sound. So there ya go... Set it at 0%
- Now use an Aux envelope to set the pulse wave above 0% by increasing decay and amount.
- also use the mod matrix to modulate the decay of the Aux with the Aux itself. You can create punchy clicks this way for your resonant noise based hihats and rides without losing the noise tail by needing the amp env, and being able to use both digital oscs.
To use the pulse width method like an on/off switch use one of the LFO's via mod paths:
- set pulse wave above 0%, 50% for instance.
- in mod paths set LFO 1 to control pulse width of osc 2 by a negative amount, -127 for instance
- Set the LFO to square and a rate slow enough so it doesn't start a new cycle.
Not exactly a volume knob, but at least an extra on/off switch method
