Latest SoundTower Editor 1.6.1
Re: Latest SoundTower Editor 1.6.1
« Reply #20 on: March 14, 2019, 04:12:08 PM »
For some or another reason, Soundtower does not receive anything from my rev2. So, I can change parameters on my rev2 from soundtower, I can also select user programs. However, Soundtower does not receive knob turns, nor does it receive my program names, let alone the settings belonging to these programs.
I am connected over usb and have selected rev2 for midi in and out ports and for midi in keyboard controller. I would love to learn what I am doing wrong.
« Reply #21 on: March 14, 2019, 07:14:18 PM »
Mine doesn't either. I'm not sure if it is supposed to or not.
« Reply #22 on: March 14, 2019, 07:57:13 PM »
In the Rev2 Globals Settings:
MIDI Sysex Enable: ON
MIDI Sysex Cable: USB
MIDI Out: USB
MIDI Controller Enable: ON
MIDI Parameter Send: NRPN
MIDI Parameter Receive: NRPN
Soundtower Editor > MIDI > Midi Setup:
Make sure you have Rev2 selected for both MIDI IN and MIDI OUT ports in.
« Reply #23 on: March 15, 2019, 03:57:08 AM »
Thanks, Creativespiral. I just connected my Rev2 again to go and see whether I have different settings than you described. Then, I found that Soundtower was already receiving from Rev2 as it should. So, something happened between 1) closing soundtower, 2) turning Rev2 off, 3) turn of computer (3b going to bed, maybe that was crucial :)) 4) turn computer on, 5) turn Rev2 on 6) start Soundtower, that made it work. If I figure out what made it work, I will write an update.
« Reply #24 on: March 15, 2019, 06:57:08 PM »
MIDI Out: USB
Thank you - I had one setting wrong.  I use the Rev as an external instrument in Cubase, which uses the Midi connections.  As such, I have the Rev 2 editor set for USB - I had my Midi Out set to Midi (required for the external instrument in Cubase), so I set it to Midi + USB, and now it sends to the Rev 2 editor.
Thank you again.
