REV2 expression pedal assignment problems
« on: February 11, 2019, 05:30:58 PM »
Hey REV2 players. Question regarding assigning an expression pedal to different parameters per patch. There is a global setting that has to be assigned to something. I can change the pedal's functionality fine there but using the modulation matrix to try to change it per patch, I'm not able to get anything to happen at all. Is the global blocking my per-patch settings? If that's the problem is there any way to set the global foot command to nothing?
  • 1735
Re: REV2 expression pedal assignment problems
« Reply #1 on: February 11, 2019, 08:03:52 PM »
Set the global paramter to CC#04... that is the default CC for a foot pedal, mine works fine with that in the mod matrix... I think that if you set it to CC#11, you would control it with the Expression source in the mod matrix... with CC#02 it's breath... the other settings to the filter is probably a direct assignment.
