They are the same because the REV2 is backward compatible, and 08 patches sound the same on REV2.
You can use tricks to make the envelopes mor snappy, just route an envelopes output back to its own decay parameter in the mod matrix... Positive modulation gives you a more downward logarithmic snappy curve, negative amount makes it the opposite.
