Transpose
Transpose
« on: February 08, 2019, 01:56:39 PM »
How can I Transpose in Desktop Version...
Re: Transpose
« Reply #1 on: February 08, 2019, 02:54:08 PM »
Transposition should be done on your controller keyboard or whatever is generating the notes.
SEQUENTIAL
Re: Transpose
« Reply #2 on: February 09, 2019, 03:18:14 AM »
Thanks, i have ordered yesterday . And I would Control it with The Nord Stage which have amazing
Controller Possibilities .
Re: Transpose
« Reply #3 on: February 10, 2019, 09:56:55 AM »
Does the Nord Stage let you transpose the MIDI Out? My Nord Electro 6HP does NOT transpose the MIDI out...it is locked to the physical keyboard. The TRANSPOSE function applies only to the voices internal to the Nord.
DSI OB-6, Nord Electro 3HP & 6HP, Roland SoundCanvas SC55mkii, Beatstep Pro, Minibrute 2S, MPD18 (+mpcstuff), Roland TD-4 V-drums, Fender-Rhodes Stage MK1, Reaper, plus dozens of acoustic instruments and mikes.
Re: Transpose
« Reply #4 on: February 11, 2019, 10:21:24 AM »
Yes on The Nord Stage  I have a Transpose Botton...
On each  Modul i can Control it with The Transpose Botton...
Re: Transpose
« Reply #5 on: February 16, 2019, 03:36:06 AM »
Are you sure about this? My Nord Electro 5D does allow transposition (I assume you are talking about switching up and down octaves whilst using the Electro as a controller).
I have not used it as a controller in a while, but if I recall correctly there is a bit of a quirk - I believe that you have to split the keyboard as the transposition only works from one of the split layers. May be worth giving that a go to see if tis the same on the Electro 6.
Re: Transpose
« Reply #6 on: February 23, 2019, 12:10:04 PM »
Thanx for the tip...I will mess around with that this afternoon. It certainly does not work when unsplit...the <Local> voice transposes, but the <MIDI Out> does not. I couldn't find anything in any manuals or online about this.
