« Reply #6 on: February 23, 2019, 12:10:04 PM »
Thanks, i have ordered yesterday . And I would Control it with The Nord Stage which have amazing
Controller Possibilities .
Does the Nord Stage let you transpose the MIDI Out? My Nord Electro 6HP does NOT transpose the MIDI out...it is locked to the physical keyboard. The TRANSPOSE function applies only to the voices internal to the Nord.
Are you sure about this? My Nord Electro 5D does allow transposition (I assume you are talking about switching up and down octaves whilst using the Electro as a controller).
I have not used it as a controller in a while, but if I recall correctly there is a bit of a quirk - I believe that you have to split the keyboard as the transposition only works from one of the split layers. May be worth giving that a go to see if tis the same on the Electro 6.
Thanx for the tip...I will mess around with that this afternoon. It certainly does not work when unsplit...the <Local> voice transposes, but the <MIDI Out> does not. I couldn't find anything in any manuals or online about this.
