I'm trying to automate the low pass cutoff with the gated sequencer but I struggle with values.
So I naively noted some LPF cutoff values, reported them to the gated sequencer, set the cutoff to zero and... that is definitely not the expected cutoff that are played. Also the filter cutoff goes up to 164 while gated values are stuck to 125. So I tried to report cutoff, dividing by 164 and multiplying by 125 but also doesn't work.
Anybody can give clues on how to map gated sequencer to other values? I guess it will be pretty much the same issue with any other control ?
