(a little help from...)connecting Px with Deepmind 12D
laurentluigi
« on: January 31, 2019, 01:19:19 PM »
Hello everyone,
Can someone tell me how to connect Px with the Deepmind 12D with a midi cable!?
I just want to have the sustain and why not the aftertouch and note number.
I'm a little dumb I'm CC.....
Thanks in advance!!!
« Last Edit: January 31, 2019, 01:20:57 PM by laurentluigi »
  • 1185
Re: (a little help from...)connecting Px with Deepmind 12D
« Reply #1 on: January 31, 2019, 02:28:51 PM »
One end of midi cable connected to the PX “midi out”; the other end of the midi cable connected to the “midi in” of the DM.
laurentluigi
« Reply #2 on: January 31, 2019, 09:27:54 PM »
Thanks for that!
I know the basics, but you're right I haven't explain the facts!!!
Something strange happen.
When I turn the mix button effect 1 on the Px, the LFO rate of the DM change. Even when I select "off" on the sending program and control midi menu on the Px.
That's why I'm talk about CC....
I should go deeper in this way.
And know... I'm a dumb!
Very strange thing by the way!!!
« Last Edit: January 31, 2019, 10:31:35 PM by laurentluigi »
« Reply #3 on: February 01, 2019, 09:01:52 AM »
You’ll want to disable sending MIDI CC / NRPN from the Global menu.  Setting option #6 “MIDI Param Send” to Off will prevent the Prophet X from sending MIDI when making adjustments like you describe.
  • 1185
« Reply #4 on: February 01, 2019, 09:09:47 AM »
Not at all.
And thanks to @LadyGaia for a real answer.
Also, for more info, see pages 124 and 140 in the Prophet X manual.
Good luck!
laurentluigi
« Reply #5 on: February 01, 2019, 11:48:09 PM »
The perfect answer!!!
Thanks Lady Gaia, once again...!!
laurentluigi
« Reply #6 on: February 11, 2019, 04:52:00 AM »
Hello again,
I've already tried everything to have the Prophet X's sustain pedal working by midi with the deepmind 12D...
Following advice concerning not sending progs and infos from the one and only Lady Gaia, everything is ok .... except the sustain pedal !!!!
there must be a trick....
From Midi.ot....
« Reply #7 on: February 27, 2019, 03:22:17 AM »
If you disable the sending of all midi controllers (cc) you’ll stop the PX sending sustain pedal cc#64. You’ll have to be more specific about filtering the midi controllers. This can be done on both the PX midi output stream and the DM midi reception.
Big synth stuff: https://www.youtube.com/channel/UCJkR38XLkFear5Sf9QypQvA
| Kurzweil Forte | Casio Privia PX 5s | Nord Electro 3 73 | Studiologic Sledge Black| Roland Juno Di | DSI Prophet 6 | Oberheim DPX 1 | EMU Esi 4000 | 2 x Yamaha Tx7 |
laurentluigi
« Reply #8 on: February 27, 2019, 04:41:30 AM »
Thank you, I'm going to check that tonight.
It seems a details but .... it is not !!!
