Oh, forgot to mention, the mod wheel is set to do a one octave pitch dive on all oscillators... which can be used for the last note in the phrase. The pitch wheel is set for 2 semitone range, and most of the bends in the solo are around 1 semitone, except for the long F# which is 2 semitone bend... getting the pitch bends right is really vital to this sort of solo sound... I did several takes to record that soundcloud demo last night, but my playing / bends are a bit sloppy.
Also, if you want, you can set Pressure to modulate ALL OSC FREQ by a value of 2, and then use aftertouch/pressure for all the one semitone bends, and the pitch wheel for the larger bends. Just make sure to do it for both layers if you want it to behave like that.
