VCO Pack for Prophet X
Started by Lady Gaia, January 27, 2019, 10:55:16 AM
64 Replies 107,236 Views
Lady Gaia
Full Member
I'm delighted to announce that the Erebus and Voyager samples are now available as part of version 1.2 of the VCO Pack.  Click here to download from DropBox (note that if you have an earlier version you can just download the nested sound sets numbered 20 and higher, no changes were made to the Neutron or OB-6 samples.)
Release Notes
The Prophet X VCO Sample Pack is a community effort to bring classic VCO sounds into the Sequential Prophet X as user samples.  Long unfiltered samples were captured for every key across a 73-key range from C0 to C6 to reproduce the natural variation of each instrument.  A variety of configurations appropriate to the source were used to reproduce a range of useful raw oscillator sounds.
The pack currently includes four instruments: Behringer Neutron, Sequential OB-6, Dreadbox Erebus, and Moog Voyager.
Neutron samples:
  02. Triangle
  03. Saw
  04. Square
  05. Dual Saw
  06. Dual Saw Alt
  07. Dual PWM
  08. xMod PWM
  09. Saw Trio w M32
These keymaps showcase a modern CEM3340 oscillator IC, manufactured using the same design and specifications that contributed to the core sound of classic instruments including:
* Cumar Spirit
* Moog's Memorymoog
* Oberheim OB-8 and OB-Xa
* Roland SH-101 and Jupiter-6
* Sequential Circuits' Pro One, Prophet 5 rev 3, Prophet 10, Prophet T8, and Prophet 600
The final keymap routs a dual sawtooth configuration externally through a Moog Mother-32 to layer yet another sawtooth wave for additional thickness and variety.
OB-6 samples:
  10. Triangle
  11. Saw
  12. Saw PWM
  13. Square
  14. Pulse
  15. Narrow Pulse
  16. PWM
  17. Saw xMod Square
These keymaps showcase a discrete design manufactured by Sequential as a collaboration between Dave Smith and Tom Oberheim as a callback to classic Oberheim sounds.
Dreadbox Erebus samples:
  20. Triangle
  21. Saw
  22. Square
  23. Pulse
  24. Narrow Pulse
  25. PWM
  26. Fast PWM
The Dreadbox Erebus has a classic character that is closer to pure mathematical waveforms than anything else in this pack, tending toward bright, aggressive tones that are consistent in amplitude across the keyboard.  The unit sampled here is a version 2 model.
Moog Voyager samples:
  30. Triangle
  31. Saw
  32. Square
  33. Pulse
  34. Narrow Pulse
  35. Saw-Square (every cycle the wave alternates between saw and square shapes)
  36. Triangle-Saw (every cycle the wave alternates between triangle and saw shapes)
  37. Dual Saw Square
  38. FM Saw Square (saw frequency modulated by another saw, layered with a square)
This particular Voyager has the slew rate mod which brings a little more high end content to the raw oscillators of this classic synthesizer.  Its character is achieved by taking substantial liberties with the wave shapes.  Looking for a very soft muted triangle, a nasal sawtooth, or a bright buzzy square?  This is the one.
Caution:
Make *certain* you're on the latest Prophet X firmware prior to installation.  System updates performed using SysEx do not completely update all aspects of the system and should be followed by a regular OS update using Sequential-provided .bin file.  Owners have encountered issues with versions as recent as 2.0.0.0.1, so a later release is recommended.  Version 2.1 was in beta as of this writing and can be downloaded by members of the official forum at The Official Sequential/DSI Forum - Index.
Installation:
Starting with a USB storage device formatted by the Prophet X (from the Global menu select 35-Format USB Drive), create a directory named "px" at the root of the drive.  Copy the "u02" directory accompanying this README into the "px" directory to create a directory structure the Prophet X can install (using the Global menu's 34-Update Library option, which should be switched to User mode.)
The u02 directory corresponds with the sample group User 3.  The directory name can be changed to control which group the installation occurs in, but it must be one of u00, u01, u02, u03, u04, u05, u06, or u07.  These correspond to the groups User 1-8 for reasons only a software engineer could love.
Credits:
Thanks to the GearSlutz.com community for the collective interest in getting this project started.  The first step was taken by [MENTION=307144]blewis_13[/MENTION] in providing his Neutron VCO recordings and following up with the Voyager.  OB-6 and Erebus samples were contributed by [MENTION=298357]AlanC3[/MENTION].  Sample editing, looping, and packaging by [MENTION=398507]Lady Gaia[/MENTION].
Disclaimer:
The content of this sample pack is provided AS IS with no implied warranty.  Install at your own risk, knowing that you accept full responsibility for resolving any issues that may arise.
Version History:
v1.2
- Added Erebus content
- Added Voyager content
v1.1
- Added OB-6 content
- Added Neutron samples for black keys unintentionally omitted from v1.0
- Renamed the collection to "VCO Pack"
- Revised naming to follow established Prophet X conventions
v1.0
- Initial release of Neutron VCO pack
Lady Gaia
Full Member
The newly added Dreadbox Erebus and Moog Voyager bring some wonderfully distinctive characteristics to the mix.  The Dreadbox has a classic character that is closer to pure mathematical waveforms than anything else in this pack, tending toward brighter aggressive tones that are consistent in amplitude across the keyboard.  This particular Voyager has the slew rate mod which brings a little more high end content to the raw oscillators of this classic synthesizer.  It brings a ton of character by taking substantial liberties with the wave shapes.  Looking for a very soft muted triangle, a nasal sawtooth, or a bright buzzy square?  This is the one.
Comparing the most basic classic waveforms...
Shaw
Full Member
The link to download doesn't work.
and I have a question:  I have a prior version of these samples installed (the Neutron and OB-6)... I have some programs that I made based on these.  Should I delete the entire user bank and re-install this set to the same bank number?
Also, are these samples looped?  When playing them in the PX, It seems smooth loop points were difficult to achieve (but I admit, that may well be user error on my part).
Regardless, Kudos to you guys who have worked on this.  It is great work and much appreciated by us all.
Lady Gaia
Full Member
Quote from: Shaw on January 27, 2019, 11:04:39 AMThe link to download doesn't work.
You'd think I'd remember the URL pst format here is different...
This one should work.
QuoteI have a question:  I have a prior version of these samples installed (the Neutron and OB-6)... I have some programs that I made based on these.  Should I delete the entire user bank and re-install this set to the same bank number?
No need to delete the old ones.  Contrary to what the message on the Prophet X says when you're installing to a bank, it doesn't appear to overwrite any sound sets that don't have the same numbers.  You can install these just by putting the .zip in the 20's and 30's in the usual px > u02 > 15. Synth folder structure and doing the install with just the new samples.
Presets appear to reference samples by location rather than name, so they're looking for eg: User 3 > 15 (Synth) > #03 as far as I can tell.  Those #s won't change so you're good to go.
QuoteAlso, are these samples looped?  When playing them in the PX, It seems smooth loop points were difficult to achieve (but I admit, that may well be user error on my part).
They are all carefully looped.  Using the PX interface you don't have much fine control, but sound packs can have sample-accurate loop points defined.
QuoteRegardless, Kudos to you guys who have worked on this.  It is great work and much appreciated by us all.
I'm delighted to hear people are finding them useful.  It has been a fun side project.
Lady Gaia
Full Member
So, Dropbox decided they didn't really want to provide a convenient hosting solution given the size of the content.  Fair enough, but some warning would have been appreciated.  Not to mention a reasonable path to recovery.  Ah well, live and learn.  The replacement site is definitely no work of art, but at least it's a functional workaround.
Click here to get access to the Prophet X VCO Pack released yesterday.
Shaw
Full Member
Google Drive is pretty reliable. And free.
Lady Gaia
Full Member
Google Drive might have been a reasonable option but this was a perfect excuse to start putting together a better overall experience than a basic file download service.  I've been meaning to put together a site to host projects like this, so why not now?
Shaw
Full Member
Quote from: Lady Gaia on February 02, 2019, 10:34:24 AM
Absolutely!
I've thought of sampling the Prophet 12 for use in the PX... I'm on a Mac.  Any suggestions as to software could I use to get good loops in the samples?
Lady Gaia
Full Member
Quote from: Shaw on February 02, 2019, 10:36:45 AMI've thought of sampling the Prophet 12 for use in the PX... I'm on a Mac.  Any suggestions as to software could I use to get good loops in the samples?
Everything in this pack was trimmed, gain adjusted, and looped using SampleRobot.  It's not the most intuitive or Mac-like application on the planet but it is very helpful and does a nice job of automatically finding loop points once you understand how the whole process works.
Shaw
Full Member
Is the sample set size limit of 1.5 GB, is that a limit that the Prophet cannot exceed, or a limit for the Sequential / 8dio software sample editor?
Can that be overcome?
Can users create Add-on packs to load into that memory? and also so that you can create/load companion programs for your samples?
Lady Gaia
Full Member
Quote from: Shaw on February 04, 2019, 07:45:36 PM
As I understand it, that's the limit for what a single keymap can contain.  Terminology is problematic here, but what I've called a "keymap" is the set of samples you can select for one of the two Instrument slots in a layer.  8Dio's software calls this a "sound set".  It's a completely different limit from the amount of samples you can have installed at once.
A user-created sample pack can have as many as 98 of these per category (Synth, Woodwind, Choir, etc.) so long as there's enough disk space available.   The Prophet X loads samples pretty quickly from the 200GB solid-state drive of which 50GB is set aside for user and commercial add-on samples.
QuoteCan that be overcome?
Not without changes to the firmware and I wouldn't expect anything to happen there.  Chances are there are 6GB of RAM set aside for loading two layers, times two instruments, times 1.5GB each.  That's going to be a physical limitation.  It defines how many samples you can play at any given instant.
QuoteCan users create Add-on packs to load into that memory?
Definitely!  That's what we did for the VCO Pack using 8Dio's Mapping Utility.
Quote... and also so that you can create/load companion programs for your samples?
Yes, but that gets slightly complicated because all programs (or presets in Sequential's terminology) are stored in numbered slots and there's no way to know what user programs are safe to overwrite.  There are 16 reserved preset slots in the "A" banks for each of the 32 commercial add-on banks, but no similar provision for the eight user banks.
Lady Gaia
Full Member
Once again, one of my faithful contributors has provided more raw samples that have been integrated into the VCO Pack. These add two new keymaps (or "sound sets" in Sequential/8Dio parlance) that can be downloaded and installed alongside the existing Neutron / OB-6 / Erebus / Voyager content:
Four synthesizers were stacked here. It starts with two detuned DCOs from a DSI Evolver hard panned in stereo as a foundation. A Sequential Prophet 6 contributes two VCOs alongside a subtle touch of noise, all centered to anchor the sound. There are two Moog Voyager oscillators as well, offset from center with a subtle touch of filtering to give each side a unique character, accompanied by another hint of noise. Lastly, a Moog Mother-32 adds a seventh oscillator centered in the stereo field.
The same configuration is used twice: once with seven sawtooths and again with seven pulse oscillators that have subtle pulse width animation applied.
90. Stereo 7 Saws
91. Stereo 7 PWMs
No need to reinstall the previous sounds, just download the new "Stacked OSCs" and install them into the same User Group. Despite warnings about overwriting, the Prophet X can add these to the existing group without replacing the earlier sounds.
Enjoy!
Guest
This is awesome! I really hope to see a Fairlight pack soon. I'd get that in a heartbeat.
cshorte
Commerce
Okay, so I got very brave but no joy! I created the px directory at the root of the USB drive, I copied all of the .zip files to the u02 directory and then proceeded to update the user area of the PX. It did its thing of overwriting the 50 GB area but, when I go to group user 3, I do not see any instruments in any of the created groups. Help, help .... HELP. Thanks.
cshorte
Commerce
Quote from: cshorte on March 06, 2019, 11:38:26 AM
I got it ... I needed to look under the group "synths" and all of my imported instruments are present and accounted for. Thanks for those who saw my initial post and said hummmm. Now, off to play with my new "synths"
victros
Commerce
Hello, I attempted to download this pack and extract it on my PC only to find blank folders. I tried another PC and had the same issue. The folders have no content in them at all. Has anyone else came across this issue?
blewis
Full Member
Totally blank? You use the word "extract". Are you trying to open the zip archives?
Steve in VA
Commerce
Quote from: victros on March 10, 2019, 02:28:25 PM
Try using the 7Zip (free) rather than the built in Windows .zip extractor. That worked for me.
Shaw
Full Member
Quote from: Steve in VA on March 11, 2019, 03:51:03 AM
You mean you've been able to extract the individual samples?
victros
Commerce
#19
I believe I see the issue with the help of Steve (Thank you). The archives appear to be password protected and windows cannot extract password protected files with the native zip utility. I can't seem to find the password to extract the files where I downloaded the pack http://thinkersnacks.com/px-vco-pack.html Does anyone know the password?
