When assigning a parameter (eg filter 1 cutoff) to a sequencer track, using that parameter knob to control the value doesn’t allow the full range of values to be recorded; the only way to do that is by using the dedicated “step value” knob in the sequencer section. Is this normal?
I found that I couldn’t use the sub oscillator knob to assign that parameter as a sequencer track destination, even though it is a valid destination. Normal?
When assigning oscillator shape mod as a destination I couldn’t use the “shape mod” knob to do it; it worked via the shape/noise knob. Is that right?
