Sorry, haven't used ctrlr... But most of the parameters are the same for Layer A, at least. Some are different, and there are some extra NRPNs for the additional parameters. But Layer B is not the same as the P'08 at all, instead of starting at parameter no 400 (or whatever it was on the P08) it starts at 2048 if I recall right. Which makes sense, because now every LSB parameter number is the same for Layer A and Layer B, it's just offset by the MSB by 16 steps (16x128=2048) the reason probably being that the polyphonic step sequencer occupies about 800 parameter numbers.
So, for example:
Layer A osc 1 pitch: MSB 0 LSB 0
Layer B osc 1 pitch: MSB 16 LSB 0
Layer A osc 2 pitch: MSB 0 LSB 5
Layer B osc 1 pitch: MSB 16 LSB 5
So I don't think it's possible to convert the editor, in the strict sense of the word, but you'd have to reprogram some parameters. Hopefully, you can copy paste Layer A to Layer B and just change every MSB to 16 instead of 0. I have no idea how ctrlr works though.
