Anyone using this Setup successfully ?!
Anyone? Any Advise?
I found a way, not the best, has some limitations (in my case mostly from Ableton), but it works.
You can record the automation from the hardware using the codeKnobs editor.
The editor does some neat work translating the NRPN that receives from the synth to standard midi for the host to understand and save the automation.
Then if you play the midi clip with the recorded automation, it goes through the editor, being translated to NRPN again, then go to the synth input, right?
If you can capture the NRPN the editor is sending to the synth and loopback it to Omnisphere it works.
In my case i needed to use to midi interfaces, doing all with virtual ports or with USB didn't work for me.
My routing is:
Rev2 midi OUT (nrpn, all config set to work with editor) -> audio interface midi input -> codeKnobs editor IN. (with this pipe i can persist the automation in DAW)
codeKnobs editor OUT -> audio interface midi out -> HERE GOES THE NRPN I WANT TO CAPTURE so -> midisport 2x2 IN -> midipipe to capture those messages and replicate those to a virtual port -> midisport 2x2 OUT -> Rev2 midi IN.
The midipipe "midi thru" virtual port i created is set as input of Omnisphere.
I dont know why i just cant loopback the audio interface midi out to midipipe, to avoid using the midisport, o why i cant do all of this with just usb. This setup worked for me.
Thanks, hope it helps!
