MIDI clock sync lag
Started by OBJimKenobi, January 04, 2019, 08:16:18 AM
7 Replies 18,561 Views
OBJimKenobi
Commerce
Hello
Syncing my OB6 desktop to Logic Pro 9 using MIDI clock.
When the sequencer isn't playing the BPM LEDs read ---. They don't show a value unless the sequencer is running. Also there is some lag before the OB6 matches the BPM. The numbers flicker or if the BPM has changed in Logic since the last time the sequencer was started the OB6 has to catch up from there.
Is this normal behaviour? Is it just 'cosmetic' and is the OB6 in fact synced from as soon as the sequencer starts?
It can make the FX go squiffy, delay time catching up for example, which isn't ideal.
Thanks
Jim
logan777
Commerce
Did you ever figure out what this was? Mine also does this.
Pym
Guest
Normal. Unless the clock is constantly being sent to the synth you can't know the tempo so we just use a default when we don't see clock. Then we recalculate as the clocks come in
Quote from: OBJimKenobi on January 04, 2019, 08:16:18 AM
Hello
Thanks
Jim
OBJimKenobi
Commerce
Quote from: Pym on August 11, 2019, 01:25:28 AM
Thanks for reply, that makes sense
RobustAmerican
Jr. Member
If it bothers you, look for something like "Send Midi Clock in Stop mode" in Logic. I have this setting turned on in Nuendo and the OB displays the tempo constantly. This is also helpful when working with a patch that uses the OB's ARP or Sequencer as even when the project isn't playing you can still audition the OB and hear the arp/sequencer at the tempo of your song.
I find it helpful to my workflow.
logan777
Commerce
So the delay wind up is normal?
Pym
Guest
Yes
I have an 'auto' mode in mind that will make it a bit more simple but it probably won't be rolled back into old products
Quote from: logan777 on August 11, 2019, 12:19:24 PM
logan777
Commerce
Quote from: Pym on August 11, 2019, 06:42:24 PM
Yes
Okay!  Thank you.
