Sacred Synthesis,
I've been experimenting with these panning techniques a lot over the last several days (both w/Tetra and A/B outs) and have several questions : (I realize you may not know the answer to the first few.) First, why isn't this being discussed by other keyboard players? (...not even here on the DSI forum?) Why haven't I heard of this before? I've been playing synthesizers for over thirty years and read more than many about the best ways to sound good. Is there something I can read that discusses this more? I mean, these are not subtle differences. The results are huge. Why isn't there an outcry to capitalize on these differences from a synthesizer design standpoint? Why can't a keyboard be designed that gets us these results with a single instrument?
Yes, basically. I suppose at first thought it seems as if I'm running an instrument in stereo, but then panning it to only one side, thus losing the other side. But the Prophet '08 is a mono instrument with a panning circuit; it isn't truly a stereo instrument. The only stereo-like sound it creates is that of individual notes jumping from one side to the other, or a certain stereo field in the unison modes. So, as long as you're not using the Pan Spread parameter, you're not losing half of the sound by panning at the mixer.
So you disable all Panning parameters? This is mainly done by keeping Pan Spread at 0?
If so, couldn't we use just the Left out of the keyboard and the Right line out of the module... saving some cables and channels?
>>...Then I realized it was because the PEK's oscillators are hardwired to different sides.
So, one oscillator only comes out the Left channel and the other only comes out the Right? Is there no way to set up a sound like this on the '08?
Is there a way to know from a spec sheet whether an instrument is wired more like the PEK or the '08?? What about the OB6 and Prophet 6?
I have other questions, but that's more than enough for one post. Again, I really appreciate your knowledge and help.
-Jason
Jason -
I'm laughing at your response! Yes, I'm as mystified as you are as to why this technique is not considered and discussed more on a serious level. I know it has been just a bit on GS in response to some of my postings, but that's about it. Even on the two DSI forums, it's been met with indifference. I several times suggested this technique with the Prophet 12 as a means of improving its some times unsatisfactory digital tone, and the response has been, "Yes, the P12 can achieve a stereo field through modulation. And so?" Yet, I've never found a recording of a person doing so. If the complaint is made that it's just too expensive to buy both keyboard and module versions of either the P'08 or the P12, then my obvious response would be, "Try using the Output B option. It's the same thing, but with half the voices." Hence, my second Prophet '08 Keyboard is used mostly for monophonic purposes, and I have it set up using the Output B jacks. Whatever the program, I copy the Layer A sounds to Layer B, and pan at the mixer. And this creates a stereo monophonic synthesizer.
On the Prophet '08 Keyboard-Module pair, I normally eliminate panning by leaving it at 0. Otherwise, there can be inconsistencies in voice volumes. The reason I don't then use only one P'08 output jack from each unit and save on mixer channels is that I want the option to use the Pan Spread here and there. It is useful at times, for example, with the unison mode.
With the PEK, you have several stereo options, by means of an Output Pan parameter. The oscillators can be entirely panned, moderately panned, or set to mono. I think this is one reason that some people think the instrument sounds thin. If you use in stereo just the analog oscillators or just the digital, then you have two sound sources that are completely removed from each other to opposite channels. The result is the elimination of oscillator beating. As you draw them together with this parameter, the beating begins and the sound fills out. But if you leave them in stereo, it can sound as if you're using only one oscillator. It becomes crucial when using something like a classic sawtooth lead. However, when using all four oscillators on a thick rich pad, full stereo is compensated for (since there are now two oscillators coming from each channel) and it sounds just fabulous.
The Poly Evolver Keyboard has a brilliant design, and I don't know why Dave has not copied it on his later instruments. It also provided me with much food for thought - this stereo issue - and I learned a ton from it. Never before had I thought about this subject.
I don't know which non-DSI synthesizers are stereo, but I would expect each company would be more than happy to brag about it on a spec sheet. As for the Prophet-6 and OB-6, I believe they're mono instruments with stereo panning and stereo chorus. Some one can correct me if that's not right.
Then again, there is now a Prophet-6 Module, isn't there? Tempting....
