I'm having an issue with the MIDI sends on Rev2, when playing STACKED programs.
In Globals, I set MULTI MODE to OFF.
Whenever I strike a key, I'm getting two NOTE ON events followed by two NOTE OFF events. Doesn't matter if using USB MIDI OUT, or 5-PIN MIDI OUT... same results either way. All the events are on Channel 1, which causes issues with other attached devices (my MPC-X for instance)... There are two identical NOTE ON events on the same channel 1, followed by two NOTE OFF events.
I can understand sending a separate NOTE ON for Channel 1 and Channel 2 separately, when MULTI MODE is set to ON, but when setting MULTI MODE to OFF, the board should only send one NOTE ON and one NOTE off per key strike.
Does anyone have a workaround for this, or is there another setting I'm missing that will make it so only a single note on event is sent when playing a stacked patch?
