Saving MIDI System Settings..
« on: October 23, 2018, 02:19:46 AM »
Hi, I seem to be having trouble with the MIDI settings on my tempest. Everytime I turn the device on it reverts the MIDI system settings to Master/No Midi in selected. I keep having to manually change it to Slave Thru and MIDI PORT every time I turn on the device which is quite annoying.
I don't remember having this issue a few years ago, and a studio I worked in had their tempest synced automatically after the device is switched on. I have RTFM but cant seem to find help.
Any ideas?
Re: Saving MIDI System Settings..
« Reply #1 on: October 23, 2018, 03:16:28 AM »
Definitely you should contact support maybe it has to do something with the board that needs repair or replaced..
« Reply #2 on: October 23, 2018, 03:25:57 AM »
Aw man, I have had trouble with the Tempest since I got it in 2014, the play/stop/record buttons were loose, I sent it off last year to have it fixed as it was still under warranty with the supplier, when i recieved it back the LP filter constantly changes by itself (a known problem on here). I have recieved a new potentiometer from DSI to fix it myself.
If this is another thing that needs fixed and will cost me money I will absolutely give up the Tempest.
Nothing but trouble from day one.
« Last Edit: October 23, 2018, 03:28:25 AM by ionawax »
Jimger
« Reply #3 on: October 27, 2018, 04:08:31 AM »
Hi Yorgos,
This is my first post, I've recently bought a second hand Tempest.  I've found your contributions on this site extremely helpful when I've been learning about the tempest and thanks to this I'm starting to get to know it a little... so many, many thanks.
I was a little puzzled and worried by this post though...  my tempest isn't remembering my midi setting, I have to set this every time I turn it on.  It's not really difficult or problematic.  Everything else seems to work fine.
I wondered why this could mean a new board?  Seems a bit drastic for what seems like a small issue...  Is this the start of a bigger issue or something?
Cheers,
Jimmy
« Reply #4 on: October 27, 2018, 07:29:17 AM »
Welcome to the forum and thanks for the kind words Jim!
What OS versions you have installed?
« Last Edit: October 27, 2018, 07:31:37 AM by Yorgos Arabatzis »
Jimger
« Reply #5 on: October 27, 2018, 07:56:45 AM »
Hi Yorgos,
I have 1.5.0.2 Main OS
Voice OS: 1.5 (x6)
Panel OS: 1.3
Sam OS: 1.1
I reloaded (?not sure if my terminology is right) the first three of these yesterday.  They were already up to date but I thought is was worth a try.  It didn't seem to help.
I have recalibrated the tempest today also (oscillators/filters/sliders and drumpads)
It is now saving the midi settings.
I'm pretty sure this comes and goes, not sure if it's something that I'm doing.
Thanks for your help!
Jimmy
« Reply #6 on: October 27, 2018, 08:40:54 AM »
Some boards are having a battery inside for saving purposes..I don’t know if that’s the case with Tempest  but it’s worth it to get in touch with DSI support..They know better
Hi Yorgos,
Voice OS: 1.5 (x6)
Panel OS: 1.3
Sam OS: 1.1
Jimmy
Jimger
« Reply #7 on: October 30, 2018, 10:06:34 AM »
Will do Yorgos,
Thank for the advice.
Jimmy
« Reply #8 on: October 30, 2018, 01:45:21 PM »
Sure Jim any time ;)
Will do Yorgos,
Jimmy
« Reply #9 on: November 20, 2018, 10:01:42 AM »
Hi everyone,
I contacted support and Carson was very helpful.
So...
I missed a trick here with the ‘Settings’ button.
All I had to do was press ‘settings’ when I’d altered them.
So, as I’m sure just about everyone will know but there may be a few like me who don’t:
If you want your settings to ‘set’...
Press ‘settings’ after you’ve set them!
Cheers,
Jimmy
« Reply #10 on: November 20, 2018, 03:10:52 PM »
Ah Jim thought you saw that set..Ye Carson is a nice lad ;) Glad you figured this out..
Hi everyone,
So...
Cheers,
Jimmy
