My only gripe with my beloved Prophet rev2 is the unnecessary bottleneck created by low resolution control values between the encoders, digital control layer, and analogue hardware layer (and by extension the current implementation of external NRPN control).
For a synthesiser that positions itself as microtonally capable (which was the main selling point for me personally), it would make sense to either adapt the “stepped semi-tone tuning of the filter feature” to the currently selected global tuning, or to discard it in favour of truly fine grained “one cent” steps.
Curiously, 14 bit MIDI/NRPN (which the synth already uses), would be capable of (pretty much) exactly this. If you multiply the current 164 (filter) value range (100 cents each) by 10 = 16,400. Where the maximum values possible in 14 bit MIDI = 128 x 128 = 16,384. Regular 0-128 step controls fit within 14 bit because at 10x the resolution this would be 12,800.
I think the human ear can only distinguish ~5 cent steps, so it doesn’t need to be that high, but 12 tone equal temperament semitones are at best a hinderance to my compositional praxis.
I believe that my Prophet’s microtonal little brother-from-another-mother, the Korg Monologue, uses higher resolution internal control values, and consequently feels much smoother and “analogue” to operate than the Prophet with its current firmware.
Anybody else feel limited by the 8 bit control layer on the Prophet rev2? I understand that some people prefer (or excuse) 8 bit control because you want to tune your filters in semitone steps. This is why I think that high resolution control should be a global feature you can enable or disable. This would also allow you to send 14-bit NRPN messages as control. Currently, even though the instrument accepts NRPN messages, it only accepts an 8 bit value range.
Thoughts?
