Big issue with prophet presets [SOLVED]
« on: October 19, 2018, 04:30:29 AM »
Hi everybody!
I have a big problem with my Rev 2. Since I updated it (os 1.1.4.5) every time I restart it. I have no more presets.
Every preset is the same. And If I create one, it will be duplicate on every program. I try to reload the factory presets via midi ox, but after a restart it start doing the same issue again.
My prophet is totally useless with that bug so I really need your help to fix this.
Thank you !
« Last Edit: October 19, 2018, 10:34:04 AM by extempo »
Re: Big issue with prophet presets
« Reply #1 on: October 19, 2018, 04:49:34 AM »
I just reset global setting and the problem seems to be solved. Sorry
Re: Big issue with prophet presets [SOLVED]
« Reply #2 on: October 19, 2018, 02:08:36 PM »
Sounds like you had Local Control turned OFF in the Globals. If it happens again, you can check that parameter.
SEQUENTIAL | OBERHEIM
