Startup patch [SOLVED]
« on: September 11, 2018, 12:09:27 PM »
Hi guys, seems my Pro-2, when switched on, starts up with a random bank/program. Sometimes it's the same program for days, then suddenly another patch is chosen. Couldn't find anything about it in the manual. But maybe I'm missing something here!
How is the default startup patch chosen? And is it possible to set it somewhere in the menus?
Thanks in advance for your help,
- Jan
« Last Edit: September 11, 2018, 12:34:24 PM by extempo »
Re: Startup patch
« Reply #1 on: September 11, 2018, 12:18:57 PM »
Enter and exit the global menu, i.e. press GLOBAL twice. The program from where you did this will be the startup patch.
Re: Startup patch [SOLVED]
« Reply #2 on: September 12, 2018, 12:40:43 PM »
Wow, that did the trick. Sometimes things can be sooo easy. Thanks for the quick help, much appreciated!
jmnes
« Reply #3 on: September 20, 2018, 07:36:22 AM »
This worked on Rev2 as well - thank you!
