if I set OSC 2 very high pitched and bright (so filter opened, too), and OSC 1 low and almost a sine, I clearly can hear that even on OSC 1/2 MIX = 0, OSC 2 is quite audioble.
It seems to me that OSC 2 even gets quieter until value 7 and then gets louder.
Is this a normal behaviour or is here some hardware not correctly calibrated?
I already run a OSC/Filter Calibration, it did not change it.
I read here in the forum that others had or have this problem, too? Was it fixed? could not find any definite answer. So it is a hardware problem, but affects all units?
A workaround seems to be to set OSC2 to "almost sine" in the triangle mode, and then set the pitch so high that it will be (presumably) filtered out by digital section's AD-DA conversion (higher rate than nyquist of 44100 or something?).
