I have some issues with the Prophet X that I just bought. List of issues/questions I have and pictures showing. I sent to support but no answers yet so thought I would ask forum.
All questions/issues relate to the samples that are loaded into internal memory. Synth/Effects sections seem to be working normal.
-There appears to be banks of instruments to select and then instruments under each bank type. Only instruments in banks 1-7 load. The other categories after 7 only display "error" on every instrument.
-The numbers next to instrument seem to skip. For example category 1 could go straight to instrument number 18,19 and then skip to 27. I thought for a second that maybe these numbers don't overlap and just needed to be in a different instrument set to see the other numbers but it appears they do overlap.
-Instrument number 1 on every bank just has "----". This seems odd to me and trying to figure out if normal operation.
Even when samples say error I think they are loading. At least some are loading and obvious. I can't be sure on all of them.
