Clip light - does not work - LED peak level is not shown
« on: September 04, 2018, 10:35:12 AM »
I have a second Evolver Desktop now.  ;D
All works fine but at my 2nd one the clip light does not work
The LED is working - I tested it with another power source.
But the normal circuit seems to be interrupted.  :(
Maybe someone out there knows any solution?!
  • 1041
Re: Clip light - does not work - LED peak level is not shown
« Reply #1 on: September 04, 2018, 10:46:25 AM »
Best advice is to check the version of the OS on your new Evolver, make sure that you are running the most recent version and if its still a problem then contact the support line to ask for assistance and/or repair of the circuit board.
Also, please check the Program being played and the globals are set right.
PS: Congratulations with your new Evolver!
« Reply #2 on: September 13, 2018, 01:32:05 AM »
I have OS Ver. Main 3 and DSP 3.5
Everything in the globals seems set correct.
I play it in Daisy-Chain set both to ALL.
So the 2nd Evolver should use the same settings?!
Many Patches of the new Evolver are really distorted!
All of them makes the 2nd Evolver acting like a light Show at the clip light!
