Actually, the Minitaur maxes out at C5, MIDI note 72. That's pretty high up for bass, and would take up an unneeded extra octave on your Rev2's lower split that you would mute out.
Perhaps fiddling with transpose and setting the OSC's range you could achieve what you want. My Rev2 arrives tomorrow evening (along with my Matrix 1000, woot woot), so I'll be spending the weekend exploring. I'll hook up my Minitaur and let you know what I achieve. Sounds like we're trying to do the same thing at least as far as bass splits go.
I'm really let down with the Rev2 not being able to transmit on 2 separate channels. I'm torn on whether to return it for the desktop module, but that won't work with my live rig. I pored over the manual a few times desperately looking for hopeful clues. But the section on A/B split says it *receives* on 2 channels but mentions nothing about
transmitting on separate channels.
So much for the Rev2 (or any DSI/Sequential synth?) being a sufficient live rig master controller keyboard since it can't transmit on multiple channels, nor can it merge MIDI flows via either DIN or USB.
It's a real contrast to the fact that Omnisphere rates both the Prophet 6 and the Rev2 (as well as the Novation bass station) as "Outstanding" control surfaces for its new Hardware Synth Integration.
I'm guessing the Prophets give you a binary choice of either controlling Omnisphere or controlling your live rig, but not both at the same time. My Kronos and Privia PX-5S have much more comprehensive master controller capabilities, but to be fair, while they can transmit and receive on multiple MIDI channels, they cannot merge USB with DIN MIDI either.
The Novation X-station truly was ahead of its time as a MIDI controller:
- excellent velocity and aftertouch keyboard
- 4 keyboard zones
- MIDI in, two MIDI out/thru, and USB MIDI
- flexible MIDI in/out routing over all DIN/USB port combinations
- USB audio (2 channel), functioned as a sound card
- 2 line/mic audio inputs
- multi FX
- 8 voice mono-timbral VA synth with arpeggiator
- 3 osc, with wavetables
- 9 faders, tons of buttons and knobs, transport controls
- MIDI CC, NRPNs, sysex
- functioning pc editor
- battery, USB, or wall wart powered
- templates for common VSTs and DAWs (the original Hardware Synth integration)
- lightweight and extremely portable and rugged
Alright, enough of my X-station eulogy. I don't think anything nowadays has multiple MIDI DIN out/thru with USB MIDI merge and audio capabilities anyway, not even Novation.
I've got a new dog on tier 2. I *will* adapt the Rev2 into my gigging rig, even if I have to dig out my old 1u MX-8 MIDI patch bay...
