1st oscillator keeps jumping down in pitch as a result of MIDI
I have had a Rev 2 since they first shipped and love it, however now that I’ve stopped controlling it with the global local control on, and instead have midi out to my DAW and back to the prophet I’m noticing that if I have the prophet in a split patch, then initiate recording a clip in ableton, it’ll suddenly drop the first oscillator in the A layer patch from the C2 I have it at to C0-which obviously sounds terrible if I’m playing a low note already. Any advice here? I’ve changed the midi channel various times on the prophet...
Also it’s worth noting that I have the parameter send and receives to NRPN, not CC, however it appears that when I put it to CC this fixes it, but CC tracks parameter changes worse so that isn’t a phenomenal solution.
« Last Edit: August 25, 2018, 10:36:31 AM by Troy92Evans »
Re: 1st oscillator keeps jumping down in pitch as a result of MIDI
« Reply #1 on: August 08, 2019, 06:47:21 PM »
Hi there I'm also having this problem - did you get to the bottom of it?
« Reply #2 on: August 09, 2019, 08:25:01 AM »
I believe the modern software takes care of it. I haven’t set my prophet up in this fashion in a while though so I may be mistaken.
