Two questions regarding sample velocity
I know with Sample Velocity On it triggers two different types of samples depending on the velocity that you play your keyboard but I noticed on some of the brass samples when Velocity is off, it doesn't sound as if the sample is in "it's loudest" state (Which according to the manual it should).
Also
Is there a way to use the sample velocity as a modulation destination?
