Poly mode playing 3 voices from single key press?
« on: August 11, 2018, 05:35:52 PM »
 Basically, 3 voices play when I’m playing one note. Anyone else experience this?
 Is it a setting I don’t know about?
Ed
Re: Poly mode playing 3 voices from single key press?
« Reply #1 on: August 11, 2018, 07:07:06 PM »
Go into Global, scroll to page 2, and set the voices for the total number you'll be using (if you're poly chaining.)  Otherwise, set it to "Off."
- Henry David Thoreau
« Reply #2 on: August 11, 2018, 07:43:49 PM »
It is set to off.
 Now it is playing 2 notes for one key press btw!
Can deoxit be causing it?
« Reply #3 on: August 11, 2018, 08:16:05 PM »
Well, at least that's a little progress!
So, you used deoxit to clean the parameter housings?  If so, perhaps you need to work each parameter for a while - meaning, rotate it many times to work in the deoxit.
Re: Poly mode playing 3 voices from single key press? Solved
« Reply #4 on: August 12, 2018, 06:32:49 AM »
 It was a MIDI loop going on.
« Reply #5 on: August 12, 2018, 07:57:20 AM »
Glad you figured it out.
Rule #1: When you're having a technical problem with an instrument, unplug everything before going another step.
« Last Edit: August 12, 2018, 08:30:16 AM by Sacred Synthesis »
