I believe I found a LFO related bug. Possibly it is similar (or the same?) to this one already mentioned (which supposedly was solved):
https://forum.davesmithinstruments.com/index.php/topic,2061.0.htmlThe thing is: in some patches with some notes the LFOs do strange things:
First Example: F4P9 Clavia Mello. Notes B2, C3, B5, C6 (mostly this last one) sound extremely rare and dissonant. If you set off the destination of the 2nd LFO, most of the problem disappears. (However, if you repeatedly play note B2, you'll note that there is still some LFO-thing going around badly but it does not sound so bad as in the beginning). I find this quite sad because this is one of my favourite patches
Another example: F2P82 Canadian. Press B2, it sounds broke. Then play B5, it sounds worse.
And a third one, this time citing the author of the post above:
Here is how to recreate the bug:
1. press Transpose Down/Up and Hold button to initialize a program.
2. Set LFO1 destination to Osc1 Freq
3. Set LFO1 Amount to max
4. Set LFO1 Frequency to 58
5. Play the upper last octave of the REV2 keyboard
somewhere in the middle of this octave you'll start to hear the LFO acting strangely... it happens with all the waveshapes, and at any rate setting... at lower rates you can easily hear what is going on... the amount has to be quite high before it starts to break up, and the amount for that will depend on the waveshape you choose, but all of the waveshapes does this.
In my case, using former configuration, it happens from E3 to G4.
My actual OS version is 1.1.4.9 but I also did that with the 1.1.4.5 and was the same.
Does this happens in your rev2?
