Pro 2 crashes
Started by sofine, February 01, 2016, 06:06:47 AM
19 Replies 21,620 Views
sofine
Jr. Member
I can reproduce a crash in my Pro2 each time I scroll through the seq track destinations while the sequencer is playing (in master mode, doesn't happen in slave thru mode).
Can anyone else repro this?
I'm on OS 1.2.0.2 (I bought a new Pro 2 only a few days ago which is why I think I have this OS installed)
Cheers,
Simon
BobTheDog
Full Member
Hi Simon,
I' guessing that may be a 1.2.0.2 problem which most of us don't have yet!
Probably best to contact DSI.
sofine
Jr. Member
Did you get a chance to try it out?
Yes, I've already emailed DSI support,
Thanks
Simon
BobTheDog
Full Member
Mine doesn't crash but I'm on 1.1.15.
sofine
Jr. Member
OK, thanks Bob.
Any relation to Rex The Dog? :) He did a fantastic remix of Heartbeats by The Knife
BobTheDog
Full Member
Not that I know of but you can never tell with us dogs ;)
Pepe
Commerce
i can confirm on 1.1.15 that scrolling through destinations in an empty track while sequencer is running in slave/master mode does  crash/freeze and requires a restart, its happens when destinations reach midi tracks , happens every time
BobTheDog
Full Member
I just tried again on mine to check and it doesn't crash, maybe I am doing something different.
Can you give me the exact steps needed to replicate?
sofine
Jr. Member
Quote from: Pepe on February 01, 2016, 03:34:03 PM
Thanks for that Pepe.
Carson from DSI got back to me and said
"When you have encountered the synth crashing when changing the sequencer destinations, do you have any MIDI running to and from the synth? If so, please disconnect all MIDI connectivity from the synth and check whether the crash is still present."
I haven't had a chance to check that yet, will do this evening. BobTheDog - worth a look too?
blewis
Full Member
I don't understand how a production worthy OS - if 1.2.0.2 is shipping to people its production worthy - ships without being available on the website or in the forum.
And this seems to be happening more frequently: P12, P6, and Pro-2. By all means continue moving forward, I just don't get why these OSes ship secretly.
bobule
Commerce
i had this problem and it was cured by resetting globals. my guess is globals need resetting after an os update..
sofine
Jr. Member
Thanks bobule. That made no difference though, I'm still getting crashes every time.
Pepe
Commerce
Quote from: BobTheDog on February 01, 2016, 11:44:05 PM
today without changing anything it doesnt crash, i can scroll through track destinations..strange! same setup, I've tried both clock in master and slave, all combinations disconnecting cables, trying to create an external feedback loop through a daw, zilch. but yesterday it crashed every time . this happened before and i didn't really pay attention during sessions , just went ahead rebooted and continued.. not sure if an external midi feedback loop was the cause, i think its an internal issue, scrolling destinations and upon reaching midi out, something activates a loop ? midi-destinations is where the bugger sits for sure.
bobule
Commerce
I could make it happen on any patch, just play the sequence free running, hold track select and hit track 2 then twirl the dest knob (4th one above the screen).
When it reaches Track 2: Out 2 CH16 it freezes the pro-2 and stops all sound.
sofine
Jr. Member
So, after a bit of back and forth with DSI support, we have a confirmed bug:
"Thank you for confirming that. I have replicated the crash and have verified that when MIDI clock is sent to MIDI out 1, the synth will crash when the sequencer destination is changed while the sequencer is in playback. I've added the bug to our list and it will be fixed in the upcoming OS version."
bobule
Commerce
ah yes confirmed here also, i see the globals reset just turned midi clock out off. once i enabled it the bug reappeared! good work!
sofine
Jr. Member
Yeah. Good to see DSI are still working on the Pro2. I've only had it under a week now but I'm so impressed with it, sound/feature wise. It was under my radar for so long!
bfrombmore
Commerce
Same bug experienced here.  I'm glad DSI is aware of this and hope a fix is forthcoming. (OS version 1.2.0.2)
Robot Heart
Full Member
Any bug with that severity will get fixed.
SEQUENTIAL | OBERHEIM
Zardonic
Commerce
Antihero
I just had that bug today. Thankfully it's a very specific bug that can be reproduced and not a case of a faulty unit.
Fantastic synthesizer. If that's all of the issues I will encounter with it, I have no complaints about my purchase at all! :D
