Every program I made sounds like crap with OS 1.1.4.9 [SOLVED]
Re: Every program I made sounds like crap with OS 1.1.4.9
« Reply #60 on: August 07, 2018, 12:03:07 PM »
The calibration hang up has happened to me on a few different firmwares since purchase. I got mine used though, not direct from DSI.
I can post my serial later this evening.
cbmd
  • 491
    • Sequential
« Reply #61 on: August 07, 2018, 12:27:58 PM »
To note, you should not have to calibrate the synth multiple times.  We had changed some of the calibration procedures to tighten voice to voice PW on recent BETA OS versions.  Due to the change in the calibration, it was advised that after updating the OS, the calibration data should be cleared and then instrument recalibrated thereafter.
To clear the calibration data from the synth, hold both TRANSPOSE UP and DOWN buttons and press the GLOBAL button.  Navigate to the CLEAR CALIBRATION parameter and press the WRITE button.
Power cycle the synth and then perform the oscillator/filter calibration routine.  Again, you should only need to calibrate a single time.
I hope this clears things up!
Product Designer
cbmd
  • 491
    • Sequential
« Reply #62 on: August 07, 2018, 12:28:56 PM »
Also, please remember to reset the global parameter preferences after loading the most recent OS as new globals have been added.
Product Designer
