OK, please do not laugh if this is a stupid question although I have read the manual under the Oscillator and Shape sections and have not found the answer.
It appears that turning the shape of Osc. 1 or Osc. 2 to the 5 o'clock position with a hard panned Pulse width results in the oscillator not being audible. What is the reasoning behind this?
The p6 manual page 15 states
Each oscillator is capable of generating triangle, sawtooth, and variable- width pulse waves. These waveshapes are continuously variable and smoothly transition from one shape to the next as you turn the shape knob. This provides a variety of “in-between” waveshapes.
and page 16 states that
Shape: Triangle, Sawtooth, Pulse—Used to select the waveshape generated by the oscillator. Waveshapes are continuously variable and smoothly transition from one shape to the next as you turn the shape knob. This provides a variety of “in-between” waveshapes.
There is no mention that putting the shape pot at the 5 o'clock with a hard panned pulse-width position will result in muting of the oscillator.
What am I missing here?
Thanks so much!
Noah
