I actually never tried the sequencer to modulate the amp attack, but normally the destination should be "vca att".
Then, enter your sequence steps: high values for steps with slow attack, low values for steps with quick attack.
2 things to take into acount:
- all modulation sources "add up" and "can't exceed 100%". Meaning, if you already had the vca attack programmed to high value (slow attack), the sequencer will not have a lot of effect to add (can only make it slower up to the max value)
- if your program has a slow release (high value for VCA release), the vca does not have the time to close substantially after each step. And because it retriggers from the value it is at, you will not hear a lot of change.
So to hear the full effect: program you patch with amp attack at zero and amp release at zero, then program your sequence
