Ok Thanks, I'm running a late 2013 MacPro (Trash can style), so I'ts a fairly modern Mac. This is something odd between Logic and or the P6. Baffled as never had this problem before, even with the P12.
Hi DiScO
I had same symptoms on Mac Pro2010(10.8.5) , Studio One3.
That's only occured in USB-MIDI.
P6 OS is 1.3.1
Unit sometime freeze may be happens more at tweeking knobs hard .
But , at Pro Tools12.5 is no problem.
I worried which caused by application? or P6?.
I tried to update MacOS 10.11.5 , but not solved.
So I did downgrade P6OS to 1.2.10b , then no trouble at the moment.
I up date to 1.2.12C again, trouble was occured!.
So I think this problem is caused by OS.
I wait and see on 1.2.10 for the present until next OS release.
unfortunately can't use velocity curve 5 is so favorite , but legacy MIDI is little latency than USB.
If it true caused by OS , I hope that will fix next update.
(sorry my English is not so good
