Feature requests
Started by drxcm, July 23, 2018, 11:58:49 AM
104 Replies 100,185 Views
tempted11
Commerce
i would love to see those parameters for the FX:
1. HIGHPASS. so important to take out low frequency mud
2. spread from mono to super stereo
3. ability to put FX on one side and dry signal on the other
tempted11
Commerce
feature request:
on/off switch for intruments / oscillators (via soft buttons in the menu would be fine)
mildwest
Jr. Member
Quote from: tempted11 on November 12, 2018, 11:57:36 AM
feature request:
Would love that too. Kind of a PITA for sound design having to turn up and down knobs and remember the settings for volume.
tempted11
Commerce
feature request: match sample loop to bpm
Lady Gaia
Full Member
Quote from: tempted11 on November 13, 2018, 06:41:21 AMfeature request: match sample loop to bpm
That's precisely what the Loop Mode setting "Sync" is for.  Is there something in particular you were expecting that it doesn't do?
tempted11
Commerce
how emberassing... i spent not as much time with it as i want to i guess (cough, cheap excuse...)
but thank you  :-[
REwire
Commerce
Free Run Loop mode for Sample Oscs.   The Last Prophet sounds reset at zeros with every keypress.   A Free Run mode would allow sampled oscs to behave like real oscs.
Dan
cbmd
Global Moderator - Sequential
Full Member
Use a random LFO to modulate instrument start.  This should give you a similar behavior as a free running oscillator when the VCA is opened.
Product Designer
mildwest
Jr. Member
Quote from: cbmd on November 16, 2018, 05:34:21 PM
Cool trick. Thanks.
cbmd
Full Member
Sure thing!
Product Designer
Full Member
I am shadow...
But will that really work? does the X have the ability to apply a random number to a voice that will not change during it's course? ... on the REV2 I've seen requests for a random source in the mod matrix that is steady thru out a voices duration... is this possible on the X? ... would routing a random LFO to the sample start position not just end in the sample resetting at random points in the sample at the LFO rate while a key is held?
Lady Gaia
Full Member
Quote from: Razmo on November 17, 2018, 02:05:56 AMBut will that really work? does the X have the ability to apply a random number to a voice that will not change during it's course? ... on the REV2 I've seen requests for a random source in the mod matrix that is steady thru out a voices duration... is this possible on the X? ... would routing a random LFO to the sample start position not just end in the sample resetting at random points in the sample at the LFO rate while a key is held?
If Carson suggested it I think you can be fairly certain it will work.  As I understand it, the sample start location is only computed once when the sample is triggered, unlike the loop start/end where changes will definitely affect ongoing playback.
cbmd
Full Member
^ this!
Product Designer
Redrain68
Commerce
I like to have the possibility (like in the V-Synth) to not restart sample after the first key is pressed, in this way long samples of speaking choir will remain in sync, for example the samples of the word Prophet X (F/4 Choir, 94 silka word prophet x)
I press C the sample start to say P----R-----then add the key E and the samples of the E key start in sync from the O region of the prOphet word  ..not restart from P....
REwire
Commerce
Quote from: Redrain68 on November 17, 2018, 04:16:18 PM
Does playing Legato allow transposition of a long phrase without restarting?   If not, that would be a good feature.
laurentluigi
Guest
I was thinking in this wish list instead of having stereo filters, the possibility to use them separately on each oscillators and let the switch on/off for the samples....!!
Imagine that !!!  ::)
blewis
Full Member
16 voice mode routes the audio through 16 filters in a mono voice. You can still pan the mono voice image in the stereo filed.
Each sample oscillator, or Instrument, in the Misc menu can be configured to bypass the LPF.
32 voice mode reduces you to one sample oscillator and one digital oscillator and routes all of that paraphonically into 2 filters.
Very flexible use of the filters. I think all of your wishes are true.
Quote from: laurentluigi on January 18, 2019, 01:30:45 AM
laurentluigi
Guest
That's a good day !!!!!!!!!
Quote from: blewis on January 18, 2019, 05:38:42 AM
tandem
Commerce
Quote from: drxcm on August 03, 2018, 08:23:28 PM
Quote from: LoboLives on July 29, 2018, 07:37:34 PM
Quote from: drxcm on July 29, 2018, 03:32:15 PM
Quote from: LoboLives on July 29, 2018, 09:28:33 AM
Quote from: drxcm on July 28, 2018, 06:39:39 PM
Some more that just made it to the Pro2
Arp Beat Sync
Sequence Lock
Was thinking about my first post and wonder if you could 'lock' a screen by holding down 'show' for a few seconds. Kinda like how holding down  'edit layer B' for 2 secs lets you exit both layers.
They mentioned that there was Beat Sync on the PX but I was having difficulty starting the sequencer in time with the Tempest last night (when set to NoS/S) But it worked perfectly when set to Slave.
I'm talking about Arpegiator beat sync.  At the moment, it's not always synced if you hit the keys at the wrong time - although the tempo is perfect, the sync isn't always right.  Fine running clock to sequencer.  It's like a quantised arp setting.  The Pro2 just got it.  It's been a feature request for a long time for me on the Prophet 6 too... Here's hoping we get it!
It might be a setting of some sort cause I recall them mentioning that Beat Sync was working on the PX.
Hmm.. can't find anything in the manual or in any settings - seems this isn't implemented.  At the very least, I can't get it to function.
Global -> 22. Arp Sync to Beat -> Quantize
kida2010
Commerce
Could there be anything added that would deal with the phasing of oscillator samples start points. I've noticed when i'm using sampled saw oscillators the start time seems to vary each time causing a phasing effect.
For most of my work this is not desirable.
Is there something that could be tweaked or added to stop it?
Thanks.
