Tips & Tricks
Tips & Tricks
« on: January 30, 2016, 04:57:11 PM »
There is a thread for this over at dsiforum.com but I couldn't find one posted here so I figured I create one myself.
Alright:
Monophonic stereo sound
As of OS 1.3 you can create monophonic sounds with wide stereo image using only a single layer, leaving the other layer free for other uses. This is due to the improved unison modes which allow you to use anywhere from 1 to all voices.
  • Make sure Unison is on.
  • Set Mode to 2 voices.
  • Set Pan Spread to 127.
  • Done. :)
  • If you want more variation between the left and right voices you can use modulation slots to affect LFOs, envelopes, pitch, and other destinations using the Random Mod source.
  • Enabling WAVE RESET on oscillators will make them start of mono and drift towards stereo provided that Slop isn't 0.
Prophet 12
Re: Tips & Tricks
« Reply #1 on: January 31, 2016, 08:08:58 AM »
Obvious once it's been pointed out, but what a good idea!
Thanks HESpook!  8)
Martin
Re: Tips & Tricks
« Reply #2 on: February 04, 2016, 06:48:58 PM »
Thanks for the tip.  I will say that I found a bug on oscillator 8 that appears to detune faster than all the other voices.  I confirmed this bug with support and they have it on the docket to be fixed.  To see what I mean perform these steps:
 - Create a Basic Program
 - Hold down Edit Layer A+B to edit both layers
 - Turn on Unison
 - Use 6 voice mode
 - Turn Detune to 40
 - Turn on Stack
 - It is at this point that both should pretty much sound the same as far as detuning goes.  They don't however.  Continue with next steps
 - At this point if you were to turn off Stack and switch between A + B the detuning would sound perfect because the first 6 voices are being used for both Layer A and B independently.
 - To truly test the detuning issues force Layer B to use voices 7 - 12 by itself by turning on Midi Multi Mode
 - At this point you can now switch between A and B layer with A using voices 1 - 6 and B using 7 - 12. (I use this mode a lot as I am typically using all 4 outs fed to quadrophonic speakers)
 - If you listen, Layer B on voices 7 - 12 are not as in tune as Layer A using voices 1 - 6.  I have to reduce Layer B's unison mode to 20 to bring it back in line.
 - I suspect a weird voice 8 because when I go from 1 voice to 2 programming layer B on voices 7 - 12 it is pretty much out of tune at 40.  Not all of the rest of the voices have this problem that I can see.
Fantom 7 | Moog One | Pro3 | Iridium | Peak | Digitakt | Digitone| Hydrasynth| 9u x 104hp Eurorack | H9000 | A&H SQ5 Mixer
Re: Tips & Tricks
« Reply #3 on: February 04, 2016, 07:06:39 PM »
Very interesting. So this is a bug on all P12s then? To be clear -- the issue is that, when using detune in unison mode, voice #8 detunes more drastically for the same value as the other voices?
Re: Tips & Tricks
« Reply #4 on: February 04, 2016, 07:15:01 PM »
That is what I've found.  Follow my exact steps and see if this happens to your 12?  This has been tested at DSI as I gave them these exact instructions.  They found the same problem.
Re: Tips & Tricks
« Reply #5 on: February 13, 2016, 05:51:50 PM »
Just FYI, the latest patch, still didn't fix the above problem.  I've opened a support case.
