New owner here.
My filter 2 cutoff knob does not seem to behave correctly. The lowest cutoff frequency seems to be when the knob is at 12 o'clock. Set to lowpass, with only filter 2 engaged, and nothing in the mod matrix affecting the cutoff frequency and a simple waveform, with the knob set a 12 o'clock, turning clockwise seems to give the full range. But turning counterclockwise from straight up, the frequency ALSO goes up, albeit by less. This is easily heard if the resonance is turned high. The same behavior is exhibited if the filter type is HP.
I also own an OB-6, so this is not me being unfamiliar with the filter, or having the filter type knob set wrong.
The numbers that are displayed when turning the cutoff knob are what you would expect, with fully down being = 0.
It is only the actual audible cutoff frequency that is misbehaving. I have tried running the filter autotune, with no luck.
Do I need to return this and get a new one? Some other arcane procedure I missed in the manual?
Thanks!!!!
