Arpeggiator Rest Question
« on: July 08, 2018, 12:30:51 AM »
Hi all!
I've had a P12K for about a month now but having trouble understanding the function of the rest in the arpegiator.
When I insert a rest into the arp sequence it does not go silent at that step but rather skips that step completely as if it were not there at all.
I'm on OS 1.4.2.3 so wondering if this is the intended function or perhaps a feature that worked when first implemented but has since broken.
Re: Arpeggiator Rest Question
« Reply #1 on: July 09, 2018, 07:27:43 PM »
 justmull,   I haven't had a problem.  Mine inserts rests as intended, and I believe I have same OS.
« Reply #2 on: July 10, 2018, 04:39:24 PM »
Thanks for replying - I tried resetting globals but still get the same result so may contact DSI to see what's going on. Made a video...
https://youtu.be/TuDXmUZRgKg
« Reply #3 on: July 11, 2018, 04:27:52 PM »
And the answer - the ARP MODE parameter must be set to ASSIGN for rests to work with the arp
Works without a hitch!
