Glide mysteriously deactivated during editing
maxter
  • 419
« on: June 30, 2018, 02:09:59 PM »
When playing and editing a patch on my Rev2 8-voice, I find that all of a sudden there is no Glide anymore. I have it in Unison mode, and when this happens, the Glide button is still lit, and when I check misc parameters the values have not changed. Ie there should be glide. Editing the values makes the glide active again. Perhaps some kind of strange bug? I'm on the latest OS. Anyone else with this issue?
-Edit
OK, so I've found I'm NOT using the latest OS, I had missed there's a new BETA out, so I'll have to check if that one fixes the problem.
« Last Edit: June 30, 2018, 02:20:04 PM by maxter »
Re: Glide mysteriously deactivated during editing
« Reply #1 on: July 01, 2018, 07:04:42 AM »
Have you tried this without anything MIDI connected to it ?
EDIT: there are two occasions where this would happen, if the GlideMode is set to either FixedRate A, or FixedTime A, and you play staccato style (lifting your fingers completely off the keyboard between each note played). The Glide would only show up between notes that overlap each other (legato style playing).
« Last Edit: July 01, 2018, 07:25:46 AM by AlainHubert »
maxter
  • 419
« Reply #2 on: July 01, 2018, 10:44:45 AM »
Thanks for helping, Alain!
No, I haven't tried it without midi hooked up, but I also had that thought and will try it for a bit.
The glide mode is set at the standard Fixed Rate, so... I think I'll hook up an extra midi connection either by doubling or the thru-jack and monitor it, to see if there's any message being sent to the Rev2 that could cause this behaviour. Strange thing is the Glide button is still lit, and when I press it twice, deactivate and activate it, it starts working again, until next time it disappears.
jg666
  • 561
« Reply #3 on: July 01, 2018, 11:15:29 AM »
Do you use the glide knob at the side of the glide button to alter the glide amount?
maxter
  • 419
« Reply #4 on: July 01, 2018, 11:22:50 AM »
Yes I do.
maxter
  • 419
« Reply #5 on: July 01, 2018, 12:08:41 PM »
So I've been playing and editing sounds for a bit now, and the mysterious problem didn't occur once. I believe it could be that I'm now using OS 1.1.3, when I had the problem I was on 1.1.0.3, so maybe it's just a bug that's been fixed already. Thanks everyone for helping out!
« Reply #6 on: January 08, 2025, 06:02:50 AM »
Just in case anyone else finds this old thread while experiencing similar issues:
I had a unison program that had glide activated and set to an appropriate fixed amount, but it would only ever actually play a glide if I first toggled glide on/off or adjusted the glide amount after selecting the program. Eventually I realized that it was a stacked program and glide was only activated for layer A. After activating it for layer B and saving my changes to the program, glide is now activated as soon as I switch back to the program. I still wonder if that doesn't make it a bug, but at least now I know how to avoid it as long as I'm happy with both layers using the glide.
