Im trying to do some sequencing and such with my Synthstrom Deluge. Im sending midi IN to the Pro2, using deluge as the master clock. Only thing is when I want to live record a part in to the deluges sequencer, the deluge has no velocity sensitive pads so Ive been using a separate midi controller, midi IN to the deluge, playing the pro2.
So I tried this before on a different synth and it worked but I also had strange issues pop up shortly after and had no way to know if it was related. I want to make sure its not going to cause any problems: can I just go Deluge, midi out> pro2... pro2 midi out>Deluge, basically using the pro2 as its own midi controller? that make sense?
