I'm trying to attach a Novation Peak module (no keys) to my modest setup of a Prophet 6 and a Digitakt.
Right now, I have it set up like this:
Digitakt -> P6 -> Peak
Now, when I am running sequences from the Digitakt to the Peak, I have to run it through the MIDI Thru port, which means I can't play it in real time with the P6 keys.
If I run through the MIDI Out of the P6, I can use the keys to play the Peak, but the sequences from the Digitakt are filtered out.
I've been through the manuals, and I can't figure out how to merge the Midi Out and the Midi Thru.
Do I need to turn off Local Control, send MIDI Out of P6 into Midi In of the Digitakt, then send the output of the Digitakt to the Peak and P6?
This seems overly complicated, especially since I just want the Peak and the P6 to play the same sequences simultaneously. I suspect that there is some easy way of doing this, and I just don't understand.
