Stupid question but how do you turn off the effects on the Pro 2
Hello DSI Team,
how do you turn off the effects on the Pro 2. Setting the values to 0 does not seem to turn them all off
Re: Stupid question but how do you turn off the effects on the Pro 2
« Reply #1 on: January 27, 2016, 09:00:48 AM »
What effects are you talking about, the delays?
« Reply #2 on: January 27, 2016, 12:09:19 PM »
Turning the amounts of the delays to zero should basically deactivate them.
« Reply #3 on: January 27, 2016, 03:21:53 PM »
Probably worth checking the modulation matrix as well to check nothing there is messing with the delays.
« Reply #4 on: January 28, 2016, 06:44:42 AM »
Yes I did that but the delay is still there. I will check the mod settings when I get home
« Reply #5 on: February 13, 2016, 10:34:51 PM »
Seems like it would be useful to be able to turn off all the effects (delays) at once.  Just one action to get a dry signal ...
Mopho 3006, Mopho X4 00879, Evolver 04737, PEK 01569, Pro2 01618, Prophet 08 05863
« Reply #6 on: February 13, 2016, 10:42:39 PM »
Hold down a delay button until all four buttons light up and then turn down the amount of all at the same time.
« Reply #7 on: March 05, 2016, 04:41:51 PM »
Thanks, @Paul Dither!  That's helpful (i probably should have known that).  Not quite one-button on/off, but maybe even more useful.
