Bad Adventure with DSI Support (Solved)
Re: Bad adventure with DSI support
« Reply #20 on: June 27, 2018, 08:00:39 AM »
...comunque ho visto che girando molto lentamente funzionano normalmente quindi sarą un problema di software o non so pił cosa.
(however I saw that turning very slowly work normally so it will be a software problem or I do not know what anymore.)
Hello Antonino.
The encoders on the REV2 have a software "accelleration" feature that will skip many values when the encoders are turned quickly. It is to allow to cover a wide range of values quickly instead of turning the encoder many many times.
It is a permanent feature and cannot be disabled.
However, the encoders should go up, or down, by only one value per click when turned slowly. If they don't they're malfunctionning.
Hope this helps.
« Reply #21 on: June 27, 2018, 02:15:46 PM »
I agree, but in order not to skip any value my encoders must be turned very slowly.
In the first boards only one encoder  jumped the values ​​and very rarely. for this reason I wonder what was the need to get me a swap of the boards twice if the new ones work worse?! ...
cbmd
  • 515
    • Sequential
« Reply #22 on: June 29, 2018, 03:44:04 PM »
Encoder response has been removed improved in the latest available BETA OS version.  The 1.1.4.4 OS version can be found at the following link:
https://forum.davesmithinstruments.com/index.php/topic,1531.0.html
« Last Edit: June 29, 2018, 06:13:17 PM by cbmd »
Product Designer
« Reply #23 on: June 29, 2018, 06:08:16 PM »
Encoder response has been removed in the latest available BETA OS version.  The 1.1.4.4 OS version can be found at the following link:
So no encoders at all now?  :o ;D
(The Mouse That Roared, 1959)
cbmd
  • 515
    • Sequential
« Reply #24 on: June 29, 2018, 06:13:02 PM »
Ah!  my bad, meant to say improved!
Thanks for the heads up!
Product Designer
« Reply #25 on: June 29, 2018, 06:41:09 PM »
Just finished updating and, man, what a HUGE improvement ! I've spend about 10 minutes trying my best to have one of the encoder skip a value, but I couldn't. They all work absolutely flawlessly now, FINALLY!
So I guess the culprit was probably that software acceleration feature that was maybe too sensitive, so that when an encoder was occasionally a little scratchy between two contacts, the software thought mistakenly that the encoder was turned rapidly, or something like that, and skipped a few values ?
Anyway, a big thank you ! It's like having a whole new instrument !
« Reply #26 on: June 30, 2018, 09:15:25 AM »
I can not believe it!!! Now everything is super perfect !!!! I'm excited!!!! Thank you so much!!! ;D
Gerry Havinga
  • 403
« Reply #27 on: June 30, 2018, 09:34:37 AM »
Ah good the bad adventure is turning out to be a good one  ;)
« Reply #28 on: June 30, 2018, 10:17:28 AM »
how do I write (solved) in the post title?
« Reply #29 on: June 30, 2018, 01:31:05 PM »
How do I write (solved) in the post title?
I've added the word "Solved."
