Prophet 08 and Voicelive Touch 2 MIDI issues
« on: April 26, 2018, 05:10:54 PM »
Hey guys,
I use my Prophet 08 for Live Performance of the band. Now the setlist is getting larger so I decided to use Program Change and change my Voicelive pedal preset with the synth’s through a Midi Cable
Program Change is working perfectly but whenever I turn up or down the volume on the Prophet, it changes the output on the Voicelive too. Is there a way to correct this?
Thanks
Re: Prophet 08 and Voicelive Touch 2 MIDI issues
« Reply #1 on: April 27, 2018, 01:04:58 AM »
Hi Mylkö,
go to P'08 global settings and set
- MIDI Control to OFF and
- MIDI Program to ON.
The first command will make P'08 neither send nor receive any MIDI controls, which will solve Your volume-problem, but also hinders pitch and mod wheels, pedal, and breath controller from transceiving MIDI-CCs. See P'08 manual page 40 for reference.
Second command will keep program change messages coming through (remember: in both directions, so program changes dialled in on P'08 will be sent to Your pedal, too)
If You need those other controllers or do not want program changes to become effective in both directions, You will have to dig deeper into MIDI and look into Your pedal's and the P'08 MIDI implementation.
Using NRPNs instead of CCs might solve problems, special cases may even require MIDI filtering. But give the method described above the first try.
HTH
Martin
« Reply #2 on: April 27, 2018, 09:17:38 AM »
Hi Mylkö,
HTH
Martin
This worked perfectly! Thanks
