I'm using a REV2 module with Logic Pro X, connected directly via USB, with local off and am experiencing a lot of REV2 lockups when manipulating even single controls on the REV2. Everything works at first, but then the lockups usually occur after around 5 minutes of manipulation of the controls. After the first lockup, subsequent lockups become more and more frequent until I restart everything. The problem even occurs when not recording tracks and simply adjusting controls.
Can anyone recommend Logic Pro X settings for pairing with a REV2 for recording NRPN data alongside notes being played? I am having the identical problem with my OB-6 as well, and am wondering if I should be using a different DAW like Cubase to avoid this issue.
Thank you in advance for your time and help (and I apologize if this post should be in a different location),
James
