Well... now that there is a thread like this I may as well use it... I have been thinking hard since this topic started a while ago, thinking hard about my new idear of non-preset machines, and in the end I'll have to admit, that it's not really an option anyway... I need to flip my "fix" from buying new gear into being a "fix" for creating music instead. It is not an easy task, but keeping up that "gear fix" for more years is simply not going to make any changes for me, I see that now. I have to switch focus from analyzing my gear options to analyzing what gear I NEED for creating the music I actually want to make.
I also realized that more gear is (in my case) not equal to more productiveness, it only fuels my gear buying "fix" needs. So I have to cut down on the amount of gear, to be what I absolutely need, and preferably so few synths that I do not need to split my focus on too many devices... that alone will provoke my "gear fix" abstinences imensely, but it has to be done.
I realized that creating ONE sound on a semimodular is nice enough, but when that first track has been laid down, the following cannot be semi modulars anymore... i need fast access to presets to keep the creative flow going.
Currently I work via HD recording, and I will do that in the future as well, because it gives me more advantages to MIDI recording... first off, I need fewer synths as they can be reused on as many tracks as I want to, and it allow me to record knob movements directly into the score... my scores tend to get much more dynamic and alive when I HD record, rather than copy/paste MIDI tracks again and again.
My Audio interface is an RME AIO with four input expander, so I've got three stereo inputs that I decided to set as a limit... that is: three stereo synths, and no more... that will be something I can comprehend, and the three devices will be learned more in depth because of this.
The type of music I'm going for is any kind of Ambient music and Berlin School types of music, but especially one band has "that sound" that I'm after... not that I want to copy their way of making music, but the tone of the sounds, especially their basslines is what I'm after... you can hear a bit from REDSHIFT here:
https://youtu.be/ttMmBRjrDXU?t=367Notice the power of those bassnotes... it's done by a MOOG MODULAR, so the first synth I would definitely need, will be something that kan produce these bass characteristiscs, and unfortunately there is no other way than something that use those MOOG MODULAR circuits, so the first synth (or actually two) I've chosen is the MOOG MATRIARCH. This synth is built on the MOOG MODULAR circuits, and sound like them... it will even provide four note paraphony as well, and it has that essential analog delay that is also needed to get the right sound out of the box.
I already have the GRANDMOTHER and have thought long and hard if I should sell it when getting the Matriarch, but I decided against it for a few reasons; 1. It fits nicely above the Matriach on my table, 2. it has an analog spring reverb which is also crucial for the right sounds I want from this, and 3. it will work well together with the Matriarch as additional modules to patch in... I will only have the stereo outs of the Matriarch connected to my soundcard, so the Grandmother WILL have to be patched in, but it does allow me to fire off basslines with 6 MOOG oscillators, 3 LADDER filters and both analog spring reverb and analog stereo delay... I think this little combi will work very well for any and all analog needs I'll have when making my music.
Now, the Matriarch and Grandmother will be the hands-on semi-modulars that I tweak, so the most logical would be to get a polysynth for device number two, and I have already decided on that one because my V-Synth GT will cover so much ground regarding this, that I actually have a hard time figuring out what the third synth should be. It's sample engine is unique, I can program it without an editor because it has a nice big display. It wil do timestretching, formant synthesis, sample percussion with round-robbin, Virtual Analog, FM, Ringmod.. has tons of cool FX... this synth simply has no match out there and is a god sent for creating pads which is what is just as important as basslines... also the fact that samples can be stretched, any modulation going on inside the samples do not change speed when transposing, so instead of creating specific presets, you can create templates instead, and get a pletora of new sounds just by switching the samples in a template... this fit's my needs tremendously since I hate having to create so many presets before I can use a machine... it will also let me do serious vocoding via microphone, create singing voices...
Will it do everything other synths like a wavetable synthesizer, FM synth etc. do? ... no of course not, but it can create sounds that cover the same tonal landscape... it has no wavetable synthesis, but specially prepared samples with timestretch and moving thru the samples sound just like it... it can not do 6 operator FM either, but it has FM between oscillators, and with timestretching you could use an FM sample and cover the same territory anyway.
I looked at what instruments REDSHIFT actually use beside the MOOG MODULAR, and the keyboards are a mixture of differet polysynths like DX7, Kurzweil sampler, Juno-60 etc... all polsynths that my V-Synth GT can easily cover ground for.
https://www.youtube.com/watch?v=sbVwhMZWI0UTo be honest, I think that I can make all the music I want with just these two(three) synthesizers, and any other syth added would just add up on the complexity and space it requires... and that's where the addiction hits you right i the face when you start thinking about it... "is this the end of synth buying!? AAAARGH!!!"... it's stupid, but it's that feeling I get when I think about it... that is where the burden lies to be honest. that is what I need to fight!
Anyway... I still have a singel stereo input left... and then my OCD kicks in... I really want to find that third synth that is NEEDED, but I cannot find it... Quantum and SUMMIT are the only two I seriously have been considering, but they would not cover much more territory that a V-Synth GT cannot except it has a more direct synthesis approach to the presets, and have more modulation options because of their modulation matrixes... I guess I will just have to let that slot be open until something is screaming at me: "YOU NEED THAT!" ... I am close to thinking SUMMIT might be that synth, but it has ONE drawback... it has menu diving, and not a big touch display to edit it's sounds... I do NOT want to deal with SoundDiver editors ever again! ...
So yes... I sold the PEAK, and that would have been sold anyway, so that's not a bad thing... the REV2 also has to go, it will partially fund the Matriarch next... the NYX and NEUTRON has been sent back to the dealer, so I at least got my money back there to help fund the Matriarch instead.
Other than this, I'm not in need of much anything else besides another foot pedal, a gooseneck microphone and a transportable recorder for samples. Everything fits my corner table having my computer and screen in the corner, the digital part to my left (V-Synth GT), and analog to the right (Matriarch and Grandmother).
The essential high quality reverbs and other FX will be dealt with using my DAW's plugins (ValhallaDSP).
Well... this was just "a bit" to let you guys into the "head of a gear addict" trying to get "clean"
